Use this procedure to display LLDP neighbor information.
The following table defines parameters for the show lldp neighbor command.
Variable |
Value |
port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Displays LLDP neighbor information on the specified port. Identifies the
slot and port in one of the following formats:
med |
Displays LLDP neighbors learned based on LLDP-MED TLV information. |
summary {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Displays the summary of LLDP neighbors of a port or all ports on the switch. Identifies the
